Pro Tools Audio Interfaces and DSP Systems
Avid audio hardware is made for the world’s most demanding audio projects. Get premium audio conversion, world-famous DSP processing, and near-zero latency in a simple home setup for a single session or across a massive multi-room facility managing thousands of tracks and multiple monitoring environments. When it comes to creating your best work, nothing delivers like Pro Tools systems.
The power of HDX
HDX changed an industry by accelerating digital signal processing and allowing ultra-low latency recording. Used on countless records, movies, and tv shows, this workflow has set the standard of DSP processing for years, making it the ubiquitous choice for serious audio professionals.
Pair an HDX card with Pro Tools Ultimate and a MTRX interface for the most customizable, scalable audio solution. Or, explore Pro Tools Carbon to get your hands on ultra-low latency HDX processing in a single rack space.
Learn more about Pro Tools | HDX
HIGH END PRODUCTION AUDIO & FRAME EDGE
Pro Tools | MTRX II
The most flexible, scalable box for high end audio workflows and multiple DAW support. Get extensive routing and monitoring control with I/O customization that supports Thunderbolt, Dante, Pro Tools | HDX, and more.
Discover Pro Tools | MTRX II
Pro Tools | Sync X
The only way to get sample accurate frame edge alignment for audio post to keep all your devices in sync with this powerful clock for Pro Tools | HDX systems.
Discover Pro Tools | Sync X
IMMERSIVE MUSIC PRODUCTION & AUDIO MIXING
Pro Tools | MTRX Studio
Dive into immersive audio with this all-in-one audio interface for Pro Tools | HDX. This fully loaded interface, with native Thunderbolt option , gives you the clarity, I/O, and speaker calibration capability to turn any room into a stunner.
Discover Pro Tools | MTRX Studio
MUSIC PRODUCTION AND RECORDING
Pro Tools | Carbon
The closest thing to zero latency recording there is: 0.7ms of latency at 96kHz. Carbon puts the HDX Hybrid Engine in a single rack space for maximum resolution audio recording and mixing.
Discover Pro Tools | Carbon
Pro Tools | Carbon Pre
Expand your Pro Tools | Carbon-powered studio or other ADAT ready interface with up to 24 mic preamps or line inputs with full 32-bit float audio. And with EUCON technology, remote control pre settings directly from Pro Tools.
Discover Pro Tools | Carbon Pre
MBOX Studio
Bring professional recording to your personal studio with a powerful 21 x 22 audio interface with 4 preamps for music and more. Capture and mix up to 24-bit, 192 kHz audio from input to output, manage independent cue mixes, and more.
Discover MBOX Studio
  • © 2025
